07-05-2012 08:35 AM
Hi educob,
to store more columns you can
- collect the data in memory and use BuildArray with more inputs...
- load the already saved file, use IndexArray to attach two more columns and save the file again...
It would be much easier to use rows (instead of columns) for each measurement!
07-05-2012 09:06 AM
thanks for the answer.
I wouldn't know how to read the file and then add the new columns.
I am a developer but in the standard languajes. This labview language is getting on my nerves.
07-05-2012 09:15 AM - edited 07-05-2012 09:15 AM
07-06-2012 01:20 AM - edited 07-06-2012 01:29 AM
Hello Smercurio,
Educob Wrote...
I can't find good examples for labview 8.2.
I have two 1D arrays of 1024 elements. I need to save each of them in a different column of an excel file.
Here developer want to save the data in Excel file. Run the code with some parameters and save in xls format. I think this will save in excel file.
Have a look with attacted generated file, Correct me if i am wrong.
07-06-2012 01:30 AM
Thanks to Himanshu Goyal I am saving 1D arrays into an excel file.
I don't know how to save individual values in controls.
Thanks.
07-06-2012 01:47 AM
Hi Educob,
Can you please elebrote your question, it may help to understant the prooble and to find the quick solution.
07-06-2012 03:40 AM
I would like, besides saving 1D arrays saving indivual values. For instance I have a control for Torque, another for power, etc.
I would like also to add a header to each column like:
alfa pressure volumen
0 1.5 0
0.1 1.6 0.1 .....
Thanks.
07-06-2012 05:11 AM
Hello Educob,
Please find the attached Vi. I hope this will work for you.
07-06-2012 05:44 AM
Thanks.
I will try to udnerstand it.
07-06-2012 06:02 AM
More Simpler........
