If you are wanting to play the files simultaneously, you will probably need to incorporate multi-threading, making sure that each avi file is being played on a separate thread. Otherwise, the files real play very choppily. You should probably make a subVI that plays the file, make it reentrant, and then call it multiple times on different threads.
J.R. Allen
