I am stuck in this VI help please
hi guys,
Could you help me? I am studying Labview from a book and I could not find a way to form a component. I took a printscreen on and add it a paint file on the attachment. The componenet that I could not find the form is bordered by a red frame in the attachment.
Egemen
Message 1 of 11
(2,529 Views)
It's a constant. Just right-click on the input that takes this constant and choose Create->Constant, it will create what you need.
Br, Mike
Message 2 of 11
(2,515 Views)
are you sure about that it is constant? when I added constant it will show me just a value but in the scheme there is an arrow for choosing one selection.
Egemen
Message 3 of 11
(2,508 Views)
That is the Enum constant. It allows you to select the allowed values for the enum type.
Message 4 of 11
(2,503 Views)
I forgot to ask you: how did you create the constant?
Message 5 of 11
(2,500 Views)
I opened the pop-up menu of "Sample Clock VI" and then chose "Create-Constant"
Egemen
Message 6 of 11
(2,494 Views)
Maybe you missed with your click?  If you right-clicked in the right place you should see the right enum.  You have to right-click exactly on the spot where you would connect a wire to.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019 - Unfortunately now moving back to C#, .NET, Python due to forced change to subscription model by NI. 8^{
Message 7 of 11
(2,463 Views)
I am using labview 2009 academic suite. and I clicked the rgiht spot but there is no enum .
Egemen
Message 8 of 11
(2,422 Views)
It's an Enum constant as mentioned. If the VI it connects to has an Enum as input you can r-click the input and create constant and you'll get one of those. Else you'll have to create one of your own (preferably as type-def) if you want a self documenting VI.
From a funtional standpoint it's an integer and you can connect a integer constant, but it's not as easy to read what your choice is then ...
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 11
(2,405 Views)
Accepted by topic author newbieeng
Try creating a control and then changing that control to a constant.
Message 10 of 11
(2,394 Views)
