I NEED HELP TO MEASUREMENT MASS LOAD CELL, HX711, NI-DAQ USB 6008 AND USING LABVIEW
I plan to make measurement mass using a load cell, HX711, and Ni DAQ USB-6008 and using LabVIEW software.
What should I pay attention to
I'm having trouble where to connect the SCK pin
how to calibrate?
I've tried but haven't found a similar project on YouTube, someone tried it in C++ programming, but it contains a complicated library
I need some help.
Thank you very much
(489 Views)
How to ask questions
What have you done so far ?
(483 Views)
According to Arduino with Load Cell and HX711 Amplifier, the HX711 communicates with the microcontroller using two-wire interface (Clock and Data).
Unfortunately, USB-6008 only supports static DIO but not hardware-timed digital waveform. It is not a good candidate to work with HX711. Reference: Maximum Digital Output Frequency on USB-6xxx Devices
(423 Views)
