09-09-2013 06:08 AM
how to combine or merge the 1D array of digital waveform with a simple digital waveform. As givien in the attached VI, I want to display the datalines graph & control lines graph in a single digital waveform graph.
Thanks in advance
09-16-2013 10:37 PM
Hi gurum,
Well, you can use 'Build Array' to merge the 2 1D arrays and connect the output to the Digital Waveform Graph as shown below:
Hope it helps
Warmest regards,
Lennard.C
