How to change the TCP/IP settings of the LAN connection from LV?
How can I change the LAN connection properties? Specialy the TCP/IP properties.
kr,
Jan Wijman
Message 1 of 9
(3,864 Views)
Accepted by janwijman
search the forum here. Go through all the links and post if any specific help required.
Message 2 of 9
(3,856 Views)
I think the user is asking how to change the actual connection properties, as one does through the operating system. The answer to this question depends on the operating system. If you're on Windows. In that case, remember:
For example:
http://www.petri.co.il/configure_tcp_ip_from_cmd.htm
You can call external programs using the System Exec function.
Message Edited by smercurio_fc on 12-31-2008 09:36 AM
Message 3 of 9
(3,840 Views)
smercurio_fc wrote:
Bonus points for managing to use that emoticon withOUT coming across in an arogant manner!
Ben
PS Yes I intended to write "without".
Message Edited by Ben on 12-31-2008 09:43 AM I failed to include the letters "out" when trying to type the word "without".
Message Edited by Ben on 12-31-2008 09:45 AM
Message 4 of 9
(3,837 Views)
Ben wrote:
Bonus points for managing to use that emoticon with coming across in an arogant manner!
I hope you meant "without". Smiley Very Happy
Actually, I've used it before whenever I've wanted to drop a not-so-subtle hint....
Message 5 of 9
(3,835 Views)
Smercurio, will this let you run Command Prompt commands?
Cory K
Message 6 of 9
(3,829 Views)
I will help shorten your search
Netsh.exe
Omar
Message 7 of 9
(3,827 Views)
Yes. Sometimes you have to precede the command by prepending "cmd /c" or "cmd /k". If you type "cmd" at a command prompt you will see what the options mean.
Message 8 of 9
(3,776 Views)
I have created a Community Example Program which uses the mentioned netsh commands. It performs the scanning of WiFi hotspots nearby, lists them in a ring, shows available network profiles and connects to a chosen hotspot (kudos welcomeSmiley Wink) :
WiFi Network Scanning and Connecting with LabVIEW - Discussion Forums - National Instruments
https://forums.ni.com/t5/Example-Program-Drafts/WiFi-Network-Scanning-and-Connecting-with-LabVIEW/ta...
Eric H.
Applications Engineering
Message 9 of 9
(2,796 Views)
