06-04-2012 09:09 AM
Hi, I am trying to covert mV/V into Lbs for a cDAQ9171 in LabVIEW. I have 2 signal channels. Now my question is how to apply 2 scales? I am using one Create Channel vi. The LabVIEW diagram is attached below. Thanks for your help in advance. Cong.
06-04-2012 04:41 PM
I believe the short answer is that it is not possible when you only use one Create Channel.vi. That being said, you may call the Create Channel one time per channel and wire the task out from the first one into the task in for the second one.
Charles
