How much current does cDAQ 9178 chassis need for USB communication?
How much current (maximal) does cDAQ 9178 chassis need for USB communication?
I have a self-powered USB hub with four cDAQ 9178 chassis. The problem is that no other USB (self-powered) devices are not recognized on the hub. I want to know how much current is consumed by the four chassis.
Thank you,
Tatsuya
(3,151 Views)
Accepted by topic author tatsuya1
Hi Tatsuya
As described in cDAQ 9178 SPECIFICATIONS:http://www.ni.com/pdf/manuals/374046a.pdf
The input voltage range is 9 to 30 V and the maximum required inputpower is 15W.
At the same time ,the power consumption from USB is 4.10 to 5.25 V with 500 μA maximum.
May it help you.
Regards!
(3,100 Views)
Thank you Canon_Fan!
(3,075 Views)
