Hello, I am having some issues w/ the captureing of data. Below is
attached a sample generation of a signal that will be read in. We are
trying to read this signal in but with a continous time stamp. This is
a necessity as we will need to limit the time range to perform
calculations.
The problem we are facing is how would you create the ending waveform with a running time stamp?
We can use the "Get Waveform Components" subvi to get the Y value for
the resulting waveform and we have tried to use the sample rate to
create the time domain but everything we have been trying hasn't worked
just quite right.
We have also tried to write the Y value to a spreadsheet and then
generate a file for the time values (x value) then plot but it hasnt
work as of yet either...
Any ideas?
If you need clarification, please let me know.
