Hi, hopefully someone can help get me started on this problem...
My ultimate goal is to be able to:
1. Capture an image
2. Process it to locate the position and orientation of an object within the image (I am using 2 different size circles drawn on the object which should be easy to locate. The center of the large circle is the center of the object. Drawing a line through the centers of the two objects gives the orientation)
3. Determine the error from this data to a required final position and orientation
4. Output a callibrated control signal to manipute the object one step closer to the desired position and orientation
5. Repeat steps 1-4 until I get to the final position and orientation
Sounds simple.
But I am new to Labview and NI Vision assistant, and haven't yet been able to integrate the two. Does anyone have an example Labview vi that would create a loop that captures an image, processes it in some fashion to extract some positional data, outputs a control signal and repeats the loop until the user stops it. If I can use this as a model, hopefully I can figure out the finer details.
(Note: for test purposes I am using a USB camera, with drivers that are allowing me to capture images in Vision Assistant for processing.)
Any information that can be thown my way would be appreciated!
Neil
