07-27-2016 01:36 AM
Hi ,guys! I am freshman to labview. I meet a trouble, and need your help.
In my DAQmx data acquisition system , I need acquire data from two channels at the same time .And one of the channels need IEPE ,another one not. You can open the example by the following path : C:\Program Files\National Instruments\LabVIEW 2014\vi.lib\addons\Sound and Vibration\Example Support\DAQ\DAQmx\Frequency Analysis\Dual Channel Analysis\Baseband FRF (DAQmx AI and AO).vi . In the example , you have to configure both of them to be IEPE stage or not . There is no more information that I can search .And I have no idea to solve this problem .
Thanks in advance
regards
07-27-2016 01:52 AM
Please uss the property node method and Active channel input according to your requirements: http://digital.ni.com/public.nsf/allkb/D2D5A38279AA1431862576F20061DEEF
-The context help clearly mentions if you need customize configuration per channel, use DAQmx API.
-Don't create duplicate posts instead stick to single post: forums.ni.com/t5/LabVIEW/DAQmx-data-acquisition/td-p/3326805
07-27-2016 03:17 AM - edited 07-27-2016 03:18 AM
First ,thank you very much . It's first time for me to ask for help ,and made some mistake ,I am sorry.
I still have a problem that how do I make both channels can be selected to be IEPE or not. If I use the methods you provided just now ,I have to separate the channels ,and have to combine two channels after configure the channels, I have tried many times ,but faild . I want to make a switch that could allow users to determine every channel to be IEPE or not .
Thanks for your any help .
Regards .
07-27-2016 05:52 AM
What you tried post the update.
-You can list down all channels by using the steps in http://digital.ni.com/public.nsf/allkb/CC501982F91AFA548625735D00547AC2
-You might find the info and links in this forum: http://forums.ni.com/t5/LabVIEW/Setting-up-IEPE-settings-DAQ-MX-task-for-multiple-channels/td-p/1728...
07-28-2016 02:43 AM
Thanks for your reply , udka.
I get much help from your suggestion and link. Frankly ,I am not so familiar with the process about DAQmx data acquisition. My card is NI9234.
The following picture is my new program , an error would occur when you start running it. I thought a lot of possible reasons to correct it ,but didn't work . Can you find something wrong in my program ?
Thank you for your enthusiastic help.
mittly.
