09-02-2010 12:11 PM - edited 09-02-2010 12:17 PM
I need to make a Blinking LED (when a Boolean signal is available) in my small project (using the display LED in Labview, not the real LED ).
How can I do that?
Is there a available function in the Labview for LED blinking ?
Thanks for your help!!
Jack2
09-02-2010 12:14 PM
This question has been asked before. A simple search would have revealed the answer. Right click on your LED and select Create - Property Node - Blinking. Wire a True constant to the property node to make the LED blink.
09-02-2010 12:14 PM
Do you mean an LED display on your program, or an actual blinking LED semiconductor? There have been numerous discussions on this forum, a few in the last few weeks, about making an display (indicator in LabVIEW speak) that blinks based on various input. If the question is about a hardware one, what do you want to cause it to blink, what hardware do you plan on using?
09-02-2010 12:31 PM
thanks a lot !
jack2
09-02-2010 02:32 PM
we'll never know 😉
06-22-2015 09:57 AM
den after wiring what v have to do with d existing led???
whether we have to remove dat existing led or we have to connect dat existing led wid blinking led????
plz rply asap
06-22-2015 10:44 AM
thakurshubh wrote:plz rply asap
Please start a new thread and explain what you want to do. This thread is 5 years old!
Explain what an "existing led" is (hardware, on front panel, etc.).
Maybe attach your VI.
