03-08-2007 03:28 AM
03-08-2007 04:22 AM
You can try to use ActiveX or dll's!
BR, Christian
03-08-2007 04:58 AM
03-09-2007 11:48 AM
Hi umitc,
There are some very good examples on how to do this in the LabVIEW example finder. My personal favorite would be Call DLL.vi. Hope that helps.
03-12-2007 03:34 AM
Thank you very much for your help.
I tried the example and I wrote such a dll but when I try to use the same dll in a VS C++ project and a labview project, te dll uses different memory location. When I sent a value to dll and when I try to see it in my vs C++ application, I could not see the values. How can I communicate with my VS C++ and labview project. The dll must use the same memory location for my aim.
Best ragards,
Umit
03-13-2007 12:18 PM
Hi umit,
I am a little confused about what you are saying.
1) Do you have exported functions that LabVIEW can call?
2) Are you receiving an error?
3) How does your DLL differ from the example?
03-13-2007 01:25 PM
Best ragards,
Umit
As you have already seen, LabVIEW and VC++ running in their own process. The memory space is not shared between process.
What you need is Inter-Process Communication. Call Dll.vi alone is not going to slove your problem.
If you are a good C/C++ programmer, search MSDN site for Inter-Process Communication. There are a few choices.
You have to impliment one of those method in a dll, so you can call the dll in LabVIEW.
George Zou
