04-28-2006 05:16 AM
04-28-2006 06:53 AM
If your subvi is inside the same loop as your plotting chart, then the vi will not be plotting data until the sub vi is finished executing. You have a couple of options: I would recommend placing the subvi inside an event structure inside a second loop, so when the subvi is called, the main (or plotting loop) is not affected.
Let me know if this helps.
04-28-2006 01:33 PM
05-04-2006 07:35 AM
