Help with BiSS protocole
Hello everyone,
I want to intergrate on labview an absolute encoder from Renishaw.
Here it is:
http://www.renishaw.com/en/resolute-take-the-product-tour--10940
It uses Biss protocole, 26 bits.
The company provide a small soft, to read data from the device, and it look like this:
Usually it works and display the position but right now for some reasons it doesn't find the device, even though it is plug.
Anyway, would you have any tips on how I can get the data from this device/protocole in Labview?
Message 1 of 12
(5,076 Views)
Here is how the soft works when working
Message 2 of 12
(5,046 Views)
For interfacing a Resolute absolute encoder with LabVIEW, you'll need to be able to create an SSI/BiSS interface.
Typically this is done with an FPGA device, for which you have two options:
- design your own electronics interface and write your own FPGA code, probably integrating IP from icHaus (link)
- use a C-series module from SEA GmbH in a CompactRIO chassis (SEA 9521)
Strictly speaking that diagnostic system is designed for use with RLS absolute encoders and may not always work with Resolute readheads. The 26-bit should be able to, but it doesn't look like it's been set up properly. For instance, the BiSS protocol that Resolute uses contains CRC data, and it's set to zero in the screenshot. I would recommend getting in touch with your local Renishaw sales representative and asking them for support.
If you can get the E201 working, you can send and receive serial commands to and from the device using VISA - have a read of the E201 datasheet.
CLA
Message 3 of 12
(5,031 Views)
Hey thanks for your answer 🙂
That's actually what I am trying to do.
The E201 usb encoder interface is working with the provided soft, and now I am trying to communicate with it in labview with VISA
Message 4 of 12
(5,021 Views)
Oh I succeeded! Letme make a nice vi and i'll share it here 😉
Message 5 of 12
(5,015 Views)
Quick question:
Under labview, the decimal value the encoder return for the position doesn't correspond to the position on the rule provided with it in mm.
The software, does. At the beggining of the 10 cm rule it shows 0, then goes up, all in mm.
But the value returned under labview goes from about 33816691 to 33820441.
I assume there is some kind of table or algorithm within the soft to convert these values in mm.
Anyone would know how to find it and implement it under my labview VI?
Message 6 of 12
(4,976 Views)
Have you been able to develop the labview VI for SSI / Biss ?  If you have, could you post it?  What hardware did you use?
Thank you very much.
Message 7 of 12
(4,015 Views)
I am using the same E201 USB encoder. The USB is plugged directly in my PC. I have the RLS Software interface working and now I am trying to communicate with it in LabVIEW with VISA. I don't have any actuators hooked up yet I am just trying to establish connection with the Module. However, like your error, VISA does not recognize the device on NI MAX and so I can't use the Visa Serial config to communicate.
Can you point me in the right direction for what I can do to solve?
Message 8 of 12
(640 Views)
Does it show up as a COM port after the USB drivers were installed?
Did you read the manual for the command for the programming command set?
-AK2DM
Message 9 of 12
(628 Views)
The answer is just to help anyone with the same issue. @MetaMgmt Needed to end communication with the RLS software before attempting to talk to the virtual COM port in NI max.
Message 10 of 12
(385 Views)
