HOW CAN WE GO INTO THE "PARTS WINDOW " OF SOUND FORMAT.CTL
hi ,
i would like to know how to go into the block diagram of the *.ctl files so as to see the various blocks used .
for eg . sound format.ctl
thanks
tanisha
(2,385 Views)
There is no Block Diagram for a .ctl file. A .ctl only has a Front Panel component and an associated datatype (for the terminal).
What are you trying to do? Perhaps there is another way.
Bob Young
(2,382 Views)
tanisha,
I think you may just want to select Window >> Show Parts Window from the menu after you open the .ctl file.
However, there's not too much of interest in there, since it's just a simple cluster of a few ring controls, and the ring controls themselves must be edited individually if you want to alter their appearance. What is it that you're trying to adjust, exactly? Maybe there's an alternative suggestion to get it done.
John
(2,373 Views)
thanks ,
(2,353 Views)
thanks
(2,352 Views)
