Graph from Array
I have problem with my program.
I can't create a Graph from my Array...
Firstly i read valuse from my file which it looks like:
Power	Density Power	Frequency	Voltage	Current
25,334650E-6	36,900306E-6	190,825684E+0	862,942045E-9	864,983974E-9
24,206653E-6	35,157042E-6	190,825684E+0	827,446001E-9	882,577353E-9
25,580297E-6	36,612237E-6	190,825684E+0	851,907600E-9	863,375192E-9
25,898957E-6	36,910784E-6	190,825684E+0	824,207802E-9	829,508508E-9
26,401393E-6	34,364417E-6	190,825684E+0	807,872595E-9	821,918377E-9
25,830897E-6	34,823581E-6	190,825684E+0	813,358895E-9	836,582956E-9
24,849543E-6	35,491383E-6	197,160889E+0	813,544546E-9	880,989262E-9
25,744268E-6	34,769462E-6	197,160889E+0	826,847838E-9	837,655477E-9
Next i want to create a Graph from the first column. But it didn't work...
What can i change in my program to solve my problem?
(2,751 Views)
use Spreadsheet String To Array Function
for plot
(2,734 Views)
Accepted by piotrek1349
Hi piotrek,
why do you read "String" when you need numbers for a graph?
And what's the problem in not using Autocleanup before posting your  block diagram?
It could be as nice as this:
Your VI tells us: you need to learn about AutoIndexing with loops, using efficient functions (like "+1"), and reading the LabVIEW help on each function!
After reading the LabVIEW help yu could simplify your VI to this:
(2,723 Views)
I would do something like this.  Use Read From Text File with the right-click option to read lines to read the first line (the header).  Then another Read From Text File to read the rest of the file as a single string.  Then use Spreadsheet String To Array to parse the file data into a 2D array.  To graph just the first column, use Index Array with a 0 wired to the "Col" index.
GCentral
(2,713 Views)
