I have a vi (1) that calls a subvi (2) when I press a button. This subvi (2) calls the vi (1) again when I press another button. I have a event structure for this button (button of the subvi (2) ) where I set to false FP Open property for the vi (1) and then I call by reference this vi (1) and I do an invoke node (run) to show the front panel of it but it doesn't work. Why?
Unfortunately, the "Run VI" method only executes the vi and it will not open the front panel. 😞 If you want to open the front panel, use the "Open FP" method, which is also located on the same class. 😉
