Extracting some part of 1-D array from 2-D array
Hello. I am using Labview 2014 and need your help.
My purpose is to calculate average of some part in test data file. I did it very easily with Excel using such function of ‘=AVERAGE(D3:D5)’. To manipulate many test data files, I am trying to automate the process with Labview.
Would you please see my attachment image file and answer the questions?
  1. Using the For Loop and the Case Structure, I can extract some part of 1-D array from 2-D array, which I want (Column 4; Row 3 to Row 5). However, there is still unwanted elements of two zeros (Column 4; Row 1 and Row 2) and affect the average calculation. How can I eliminate the unwanted zero returns so that only wanted part (Column 4; Row 3 to Row 5) can be averaged?
  2. Do you know much simpler method other than my code, which can achieve my purpose?
(3,684 Views)
Accepted by converser26
Hi Conserver,
Yes there is a simplier way to do it. And it solves both your problems :
Then you just need to calculate the average of all the values in the output table 😉
Hope it helps !
CLAMaxime -- Kudos are a great way to say thank you
(3,656 Views)
Or maybe something like this:array.pngarray - vi snippet.png
(3,648 Views)
(3,613 Views)
Thank you.
I am going to take all of your comments into my program.
(3,541 Views)
