11-07-2021 06:47 AM
I have a Vi server reference from a color box and I'd like to get the Control label name from the reference because I want to use it for a case structure
11-07-2021 09:13 AM
11-08-2021 01:47 AM
Hi Bob
The question is above and in conjunction with the attached picture. I'd like to get the label name (highlighted in red, see pic) out of the vi reverence.
11-08-2021 02:09 AM
Drop a Property Node on the Block Diagram (Application Control palette). Wire your reference to the Property Node.
The property you need is Label -> Text
11-08-2021 03:08 AM
Simply place a property node on the diagram and connect the refnum to it. Then select the property you are interested in and wire it up.
11-08-2021 07:13 AM
Hoi Rolf
Herzlichen Dank!
