DAQmx Read data to JSON file
I've got 9 channels being read by a 1Chan, NSamp (Waveform) instance of the DAQmx Read node.
I'm taking 5000 samples at 51.3kSPS
I would like to log the data to a JSON file but I'm having trouble formatting the data output to json in a format like so:
        "channel": "one",
        "data": [
                "time(ms)": 0.000,
                "value": 12.2376
                "time(ms)": 0.0194,
                "value": 13.5832
        "channel": "two",
        "data": [
                "time(ms)": 0.000,
                "value": 12.2376
                "time(ms)": 0.0194,
                "value": 13.5832
the main issues being;
I can't extract the time of each sample, as I understand it, it's not necessarily 1/51300 of a second per sample.
I can't think of the best way to convert the data output to a something I can build a JSON object from.
Kind regards,
Henry
(1,472 Views)
DAQmx data will be hardware timed to be evenly sampled, which is why waveforms have a delta-t value rather than individual timestamps.
(1,460 Views)
Assuming you are using hardware timing, which appears you are, then you can trust that sample rate being pretty accurate, at least enough that you would care.
Why are you not putting all of the channels into a single task and only do 1 read?  It would make things a lot simpler.
And why JSON?  This seems likes a horribly inefficient format for storing your data.  I would lean towards a TDMS or tab delimited text file, which are a lot more readable.
GCentral
(1,459 Views)
Hello both,
Noted on the timing thank you I'll just derive it from the sample rate. In that case a better format would be:
        "channel": "one",
        "data": [
            12.2376,
            13.5832,
        "channel": "two",
        "data": [
            12.2376,
            13.5832,
in JSON as I need to pipe the data into other software, in fact it's quite likely I'll be making a POST request with the data as the body.
I am doing one read using one 1Chan, NSamp (Waveform) instance of the DAQmx Read node so all the data is coming out of one node. I just don't know how to put it into the above (or similar) JSON format
Kind regards,
Henry
(1,396 Views)
In a single task, use the N Ch, N Sample version of DAQmx Read to read all the channels at once. You can then write the data to a cluster as shown. Note, I wasn't able to flatten any data structure that included the timestamp. Apparently, the Flatten to JSON does not like timestamps - who knew?
This code produces the JSON string as shown below:
Doug
NI Sound and Vibration
(1,365 Views)
Hi Doug,
I was able to get the timestamp value to flatten to JSON by first converting to string. When flattening to XML I could see that timestamp values in LabVIEW aren't a simple key:value pair so flatten to JSON struggles.
H
(1,345 Views)
