I have a problem generating a digital waveform on a digital output of my acquisition card.
I create a digital output task, with a clock (I don't know which one to use because I didn't understand this point).
Then, starting from a waveform of 750 points, I enter the data in the output buffer, start the task and repeat the data transmission as long as I need (number of repetitions) and close the task.
No data is generated.
Depending on the values I put in the sample clock rate, it crashes.
In short, I need your help.
I've attached an example where I've tried to set the minimum of elements,
Thanks a lot
