11-08-2020 04:29 AM
I am going through very hard time, I need to measure current, write it in ,txt file and also display in graph. When I run VI it takes very initital value and hold and write it in file, when I take manual value on same point it differes. If i take 3 to 4 values than meter stablizes and give actual value. Don't know exactly what's happening.
I have attached VI please please help me. I need to measure actual current value after meter stablize.
Please help me.
Solved! Go to Solution.
11-09-2020 12:59 AM
I have opened your code, there are a lot of missing subVIs and the architecture of code was not standard.
That's why you may face issues.
My suggestion is for you to review the appropriate examples from LabView and use them in your code (be careful with examples do not modify and save them).
Best regards.
11-09-2020 03:55 PM
Something like this should do..
11-10-2020 12:29 AM
From where did you get this Vi example?
Did you modify it by yourself?
11-10-2020 02:43 AM
Yes
i have modified it.
11-10-2020 03:36 AM
This example better to use as it is. It's intended for completing simple tasks, and you should use it without modifying.
11-12-2020 04:42 AM
Hi
Thanks for reply. Could you please send me this VI compatible with 2017. I am using 2017 and this in in higher version.
11-12-2020 12:47 PM - edited 11-12-2020 12:49 PM
Here you go. Let me know how it works for you, I have the 6517a.
09-05-2022 03:06 PM
Hello my friend,
I would like to know if you could help me with this same electrometer you have, the 6517A, could you give me your email?
