Creating a separate Sine function who's only values are above a certian amplitude
I am trying to create and graph a separate sine function on the same waveform graph that is just the first function with any Y value above a preset max amplitude. This is what I have so far. the arrays coming out of the first for loop look correct. All values where -max amplitude < Y < max amplitude are set to NaN, but something goes wrong when converting the 2 1D arrays into a waveform and I cant figure it out.
(1,612 Views)
Accepted by id6014
Hi id,
Why so complicated?
See this:
(1,592 Views)
I did have to modify it slightly, but that worked perfectly. thank you so much.
(1,573 Views)
Hi id,
Instead of using InRange&Coerce and Negate you could also use an Abs() function on the Y data and a simple comparison as I suggested…
(1,569 Views)
And why exactly do you think you need to rewrite all these properties with every iteration of the loop? Typically setting them once is sufficient and then whenever one of the inputs change (do they ever?)
(On a side note, You would get significantly better help if you would attach your VI instead of oversized pictures of disorganized code)
(1,511 Views)
Here's what I might do:
(I typically place the data with fewer points on top so it will show even if the linewidths are the same)
(1,506 Views)
