Cool stuff in LV8
Ben
Knight of NI Knight of NI
Knight of NI
Cool stuff in LV8
The following list some of the cool features I found in the LV 8 Upgrade notes.
I hope you find some of these interesting
Page 106
• In LabVIEW 7.x and earlier, when you wire an error cluster to a Case
structure, the True case becomes the Error case and the False case
becomes the No Error case. In LabVIEW 8.0, when you wire an error
cluster to a Case structure, the True case becomes the No Error case
and the False case becomes the Error case.
Ben
16 REPLIES 16
Ben
Knight of NI
Re: Cool stuff in LV8
Page 99
• The space constant has been added to the Strings palette. The space
constant supplies a one-character space string to the block diagram
Ben
Knight of NI
Page 97
When you drop the Compound Arithmetic function from the Numeric
palette, the default mode is Add. When you drop the Compound
Arithmetic function from the Boolean palette, the default mode is OR.
Ben
Knight of NI
Page 107
• In LabVIEW 7.x, if LabVIEW cannot find a VI, you must replace the
missing VI with a VI of the same name. In LabVIEW 8.0, you can
replace a missing VI with a VI of any name. LabVIEW replaces all
instances of the missing VI with the VI that you select.
Ben
Knight of NI
Page 107
• You can configure when LabVIEW loads a subVI. Right-click a subVI
and select Call Setup from the shortcut menu to display the VI Call
Configuration dialog box. This shortcut menu item is available only
for VIs open in an application instance that supports VI Server
calls—not for functions, Express VIs, polymorphic VIs, or VIs open in
an application instance that does not support VI Server calls, such as
PDA and FPGA targets. If you have a large caller VI, you can save load
time and memory by selecting the Load and retain on first call option
in the dialog box. When you select this option, the subVI does not load
until the caller VI needs it, and you can release the subVI from memory
after the operation completes.
Ben
Ben
Knight of NI
Note:
I am not trying to inflate my post count.
The 5000 charcater limit forced me to make multiple posts.
Ben
Highlighted
JeffBoettcher
NI Employee (retired)
Great finds Ben.  Smiley Happy  Another is the Find and replace you just posted in a different thread.  Lots of this stuff really enhances the usability of the product, but gets buried far down the list of marketing bullets, particularly in a release as large as LabVIEW 8.0.
The ability to choose a VI of a different name when something can't be found on load is extremely useful, but you also need to be a little more careful now - if you pick the wrong VI and then save (especially if the wrong VI you picked has the same connector pane) you can find yourself in a world of hurt.  As always, pay attention when you see the "The VI expected to be at location X was loaded from location Y."  Smiley Happy
altenbach
Knight of NI
No lame excuses, Ben!
Whenever I get close to you in post count, you start sprinting. Smiley Very Happy
Wiebe@CARYA
Active Participant
How about the auto label positioning? That is great!
In the diagram, when you move the label of aterminal, it snaps to all reasonable positions!
Wiebe.
"Ben" <x@no.email> wrote in message news:1153512611113-394775@exchange.ni.com...
&nbsp;
&nbsp;
Page 106
&nbsp;
&nbsp;
? In LabVIEW 7.x and earlier, when you wire an error cluster to a Case
&nbsp;
&nbsp;
&nbsp;
Ben
Wiebe@CARYA
Active Participant
How about some stupid stuff that is *still* in LV8?
Like this...
If you select "Find All Instances" on a vi, if there is one or more instances, it will be done quickly. If there is no instance, it takes a long time, and sometimes you have to cancel a few password dialogs. I just never understood this...
Wiebe.
&nbsp;
&nbsp;
Page 106
&nbsp;
&nbsp;
&nbsp;
&nbsp;
&nbsp;
Ben
