Convert c Struct to LabVIEW and over UDP
I need some help converting this c Stuct into labVIEW so that I can send a UDP packet to a BiRA power supply controller model # 1253.
The specific struct is this...from documents sent from BiRA
Set Power Supply Current Ramp (0xC1 and 0xC2)
The 0xC1 and 0xC2 commands set the power supply current and return status bytes 0 and 1. For the message to be processed successfully, the power supply must be turned on in remote mode and not presently ramping. If the ramp state is hold, the current ramp is aborted and the new request is processed.
The 0xC1 and 0xC2 commands are the same except that the 0xC1 command starts ramping immediately while the 0xC2 puts the ramp in the hold state waiting for a hardware ramp signal.
Each command can specifiy from 1 to 5 individual ramp setpoints. The setpoint defines the current at the end of the ramp and the time of the ramp.
The ramp time is specified by an unsigned 16 bit word. The units are 0.01 seconds for normal ramping or 0.05 for slow ramping, configured by the Daughter board EEPROM. Commands with zero ramp time(s) are rejected.
typedef struct          // setpoint
  float  Cur;           // Power supply current **
  WORD   Time;          // time in 1/100 second or 1/20 second (slow ramp)
} __attribute__ ((packed))  setp;
typedef struct          // 0xC1 and 0xC2 command structure
  BYTE   Ctype;         // 00 command type 0xC1 or 0xC2
  BYTE   Rsp;           // 01 response code
  BYTE   Tid;           // 02 Task ID
  BYTE   Num;           // 03 Number of setpoints (1 to 5)
  BYTE   Chan;          // 04 Channel number (must be zero)
  setp   Setpoint[5];   // 05-10, 16, 22, 26, 32, Setpoint 1 to 5
} __attribute__ ((packed))  Cmd_C1;
#define CMD_LEN_C1  5   // expected length of command message without setpoints
#define CMD_LEN_SP  6   // length of each setpoint
typedef struct          // 0xC1 and 0xC2 response structure
  BYTE   Ctype;         // 00 command type, returned unchanged
  BYTE   Tid;           // 02 Task ID, returned unchanged
  BYTE   Chan;          // 03 Channel, returned unchanged
  WORD   Status01;      // 04-05 Status bytes 0 and 1
} __attribute__ ((packed))  Rsp_C1;
#define RSP_LEN_C1  6   // length of response message
** Negated when in reverse polarity
When I use their utility to send the packet, using wireshark this is what I get.c1:ff:6c:01:00:00:00:c8:42:01:00 This sends a command of C1 with a current setting of 100 and a ramp time of .01.
What I would like to do is leave everything as is and only change the current setting. Just not sure how to build this into a packet and send it over UDP.
Attached is the full command file sent from BiRA.
Note: BiRA does not know how to do this either, nor will they give us source code to look at their utility.
Thanks for any help
Joe.
"NOTHING IS EVER EASY"
Message 1 of 9
(3,764 Views)
Hi Joe,
you can "translate" by this scheme:
struct = Cluster
byte = U8
word = U16
float = SGL (AFAIK, never coded in C a lot - but it is in line with the size numbers given in your message)
So a "setpoint" is a cluster of (SGL, U16).
A Command is a cluster of (5*U8, 5*setpoint).
A response is a cluster of (4*U8, U16).
Just start with that apporach...
Message 2 of 9
(3,755 Views)
Also, based on your wireshark sample line, your transmission is little endian for the float current and the U16 time. Keep that in mind when you're packing your UDP string.
Message 3 of 9
(3,743 Views)
GerdW how do i send a cluster over UDP. Do i just wire the cluster straight in to the UDP Write command. or do i need to do a flatten to string? how do I tell LabVIEW to switch from little endian to big endian or vice versa.
i appreciate all the help so far.
another thing, for the setpoints wouldnt I have to do an array of cluster of two elements?
Joe.
Message 4 of 9
(3,727 Views)
flatten to string has an input for byte order.
Message 5 of 9
(3,714 Views)
You'll need to flatten to string before UDP Write.
Flatten to String has an input for selecting endianness.
An array of setpoints might not flatten the way you'd expect it too. (See LabVIEW Help for Flatten to String about size information)
A cluster of clusters would probably flatten correctly. In that case you would always be sending exactly 5 setpoints though.
For your use case, will you be sending variable number of setpoints? If so, you might want to consider writing your own string generator instead of using Flatten to String.
Message 6 of 9
(3,708 Views)
That is why there is also an input on the Flatten to String to prepend the Array/String size.  It is a Boolean input.  Otherwise it will be just fine.
GCentral
Message 7 of 9
(3,642 Views)
There's a caveat in the help.
If you are using a cluster with an array inside of it, the Boolean input for prepend Array/String size doesn't strip the size information.
From the LabVIEW help on using the prepend Array/String size option: "Arrays and strings in hierarchical data types such as clusters always include size information"
I didn't test it, but I suspect passing the cluster into flatten to string will suffer from this exception.
EDIT: Ran a quick test with an array inside of a cluster. The Boolean for prepend Array/String behaves as described in the help. Size information is always included.
If you put a fixed number of clusters inside of the cluster, flattening works fine.
Message 8 of 9
(3,634 Views)
That is not true! The boolean only influences if the size is prepended when the most outer datatype is a string or array. Any embedded strings or arrays are ALWAYS prepended with the size integer.
Rolf Kalbermatter
My Blog
Message 9 of 9
(3,592 Views)
