Controlling sequence with ok button
 Hi everyone,
I am trying to develop the attached structure. My aim is to see the "given location" which is randomly chosen with a python code then ask user to write an integer as an input and get log of this data. In the current situation given location is generated with time dependence. I want the structure to wait until the user gives an input and clicks to the ok button, after the clicking generate a new random "given location". I tried using flat sequence, shift register and more but I couldn't achieve my goal. Do you have any advise? Thanks in advance.
(852 Views)
Accepted by topic author Demettangolar
I solved my problem
(836 Views)
@Demettangolar wrote:
I solved my problem
Do you mind sharing your solution so that others who come later with similar problems may benefit?
Also, I would recommend that you learn about state machines. A state machine architecture would definitely be your friend in this type of application.
(824 Views)
I uploaded the VI
(753 Views)
