05-30-2022 10:09 AM
I´m struggling with a project and would be greatful if someone out there could help.
I´m trying to build a project simulating a engine. The NTC is connected by arduino and depending on the temperature, Led´s should light up.
Also, a alarm should be set (any temperature) together with a buzzer and with a LED connected from Arduino
If someone could help, I would be more than greatful.
thanks.
05-30-2022 10:25 AM
Could you please help clarify why your non-NI related question was posed on a NI Discussion forum under LabVIEW board? does your project involve any NI Hardware or Software and you are facing any issues with them?
05-30-2022 11:24 AM - edited 05-30-2022 11:25 AM
In general there are three ways of using LabVIEW with an Arduino.
Pick a method try a few things and come back with some code to show us and we can probably help you.
05-30-2022 11:44 AM
@gray6 wrote:
I´m struggling with a project and would be greatful if someone out there could help.I´m trying to build a project simulating a engine. The NTC is connected by arduino and depending on the temperature, Led´s should light up.
Also, a alarm should be set (any temperature) together with a buzzer and with a LED connected from ArduinoIf someone could help, I would be more than greatful.
thanks.
This is a school project. Be honest.
In that vein, you had better show some work you have done instead of depending on others to do the work for you.
05-30-2022 11:46 AM
I suspect that LabVIEW is a requirement for displaying information from the NTC connected to the Arduino.
The instructor must be sorely lacking or the OP didn't pay attention in class if all he has to show for it is a blank piece of paper for others to do his work.
