12-03-2009 02:01 PM
Have fun,
12-03-2009 02:19 PM
Here are some captures with these version, showing both the annotations and snippet features:
A capture with LabVIEW 2009 with an annotation.
A capture (no snippet) with annotations and arrow pointers
A capture created with LabVIEW 7.0
A snippet with annotation.
12-03-2009 02:42 PM
A big thank you to Darin ()for finding out how to make a snippet!
Ton
12-03-2009 03:38 PM
You are more than welcome, great job with the CCT. I have a few more tricks up my sleeve that I'll try to organize and share so the CCT stays ahead of the game. In another forum I have given code to Jim (jcarmody) to convert PNG pictures containing snippets on a block diagram into the code itself. This gives a very nice method for users of older versions to use the snippet feature. He should have a RCF plug-in soon for that. It should be easily converted to a VI for the Tools menu as well (perhaps as part of the CCT itself).
I have also worked to add autoselection of controls linked to property nodes as well as adding controls when a wired terminal is selected but not its source (more like snippet behavior). I have also experimented with including subVIs. Still a work in progress.
Once again, great job.
Minor note: I do like the dashed frame that LV puts around snippets.
12-03-2009 03:54 PM
Yes I like them as well, it's however something I am certain about if I should add this frame around an FP part of a captured snippet.
Ton
12-04-2009 02:43 AM
12-04-2009 03:11 AM
Wow, that looks really cool. Everyone should try it. 😉
I agree about the frame for the snippets. If I would be using them, the frame provides a much more visible sign than the header glyph.
Incidentally, while my name appears in the first post, the actual work on this version was pretty much all Ton's. My role was mostly in feedback and doing some behind the scenes stuff.
12-04-2009 05:15 AM
tst wrote:Wow, that looks really cool. Everyone should try it. 😉
I filed a feature request.
Ton
12-04-2009 06:18 AM
Darin.K wrote:[...] In another forum I have given code to Jim (jcarmody) to convert PNG pictures containing snippets on a block diagram into the code itself.
Darin,
I've posted the plugin here. I took a different path than you did in the code you sent me, but I couldn't have done it without your help. The plugin acts on one snippet at a time, rather than all snippets in a VI, using the reference to the selected decoration (snippet).
12-07-2009 06:00 AM - edited 12-07-2009 06:06 AM
Darin.K wrote:[...] It should be easily converted to a VI for the Tools menu as well (perhaps as part of the CCT itself) [...]
Here's a VI for the Tools menu. It will convert whatever snippet is selected.
