LabVIEW doesn't send anything to the port when you close it.
I'm not sure what platform you are talking about, but on Windows, we call the Win32 API function PurgeComm() to terminate all pending I/O, and then we call CloseHandle().
I have a switchbox that I have basically no documentation for. All the switchbox does is switch between 7 different channels. When I was messing around with it and sending it different commands, it would change channels (which is what I want it to do) when I would close the serial port with the close serial driver vi.
if you are saying that you only see the action you want when you close port, you may need to flush the write buffer to insure that the commands that you are sending out the 232 port have actually been sent.
