07-23-2007 05:39 PM
07-23-2007 06:07 PM
07-24-2007 04:23 AM
While you can't change the properties for a single array element, there are solutions.
For the background color, you can turn the array element into a cluster of your string (which would be transparent) and a color box which will be the background. You can then change the value of the color box and the color will change.
For the bold text, I think your only option will be to get rid of the string control and make the array element a picture control instead. Using the picture VIs, you can draw a colored rectangle and then place text inside it (and each element can have different text properties). That way, you won't even need the color box.
