Case structure possibility?
Hello there,
I am in a situation where I want to adjust a voltage if a certain condition is satisfied.  So I tried a simple case structure. the program works fine. However, I could not figure out certain functionality that I want. I basically want to keep a voltage in a range by continuously checking the conditions (Please check the pdf attached). I was able to construct the condition check part using a case structure, however, I can't figure out how to keep the updated voltages once it updates in the case structure.
(706 Views)
Sounds pretty straight forward to me, I have attached a VI that will be perfect for this application.
One of the things you are going to find out when comparing doubles is 100 > 99.999999999 and 100 < 100.000000001
Long ago on this forum post I found an "=" comparison VI that takes into account the digits of precession and made a VI that has an Enum output to drive a Case Structure.
So what you are doing can be a easy as this.
=== Engineer Ambiguously ===
(702 Views)
(672 Views)
