Cannot terminate LabVIEW application
Hello
I am using LabVIEW drivers for Pickering precision resistor card to set the resistance programatically.
I have attached the VI. I am able to set the resistance and the program does not give any errors. I am able to close manually the front panel and block diagram of the VI.
But I cannot close LabVIEW after that. LabVIEW hangs.Please let me know what can be the reason for this.
(2,276 Views)
Can you attach remaining VIs specially pipx40 close.vi
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,263 Views)
Accepted by Hemagopal
I think your best bet is to fire an email off to pickering support, they are normally good at getting back to you.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,236 Views)
