07-04-2014 01:46 AM - edited 07-04-2014 01:54 AM
To reproduce the bug please do the following.
Now check the cluster, the string present in the combo box will be present in the String control.
I have LabVIEW 2013SP1 and I see this behaviour.
07-04-2014 02:08 AM
I've seen that before, i think it's the same with most any datatype if you change order? For some reason it keeps the data order when the data type order is changed. Annoying and dangerous.
/Y
07-04-2014 03:12 AM
I have seen this behaviour when I was handling a string control and an Instrument resource name. This is seems to be happening with data types similar to string.
07-04-2014 06:28 AM
Does it work if you add a numeric?
/Y
07-04-2014 07:00 AM
With Numeric it doesn't have any impact. Only with the data types similar to string (DAQ config, Resource, etc.,)
07-04-2014 07:01 AM
Yes, i was thinking if a numeric in the cluster had any effect on the reordering issue, like if you in your example add a numeric as last element and move it first.
/Y
