I am attempting to get a pre-developed VI up and running. The developer of the VI has given access to the VI via the source code, yet when installing the VI I keep running into a few errors that seem to be more system based,
and was looking for some help on getting them straightened out.
The errors that I get when first running the Main VI and downloading the other Sub-VIs within the main VI are the following:
Utility-Graph File I-O.vi: "The File Dialog
Function no longer supports the datalog type input"
Keyfile I-O.vi: "The File Dialog Function no
When I go to run the Main VI it
won't take the backdoor keycode installed for the Main VI's encrypted activation, and gives the
message:
(1) Missing or corrupt file: C:\Documents and
Settings\jon\Desktop\Labview\Config\keyfile.dlg
(2) Missing or corrupt configuration: C:\Documents
and Settings\jon\Desktop\Labview\"Main VI's name.ini"
I went ahead and stripped the Encryption Activation program from the Main VI, and still the (1) & (2) messages
appeared.
Any suggestions?
Thanks.
