08-03-2021 05:45 AM - edited 08-03-2021 05:52 AM
I would like to associate a descriptive name to each channel. I would like the save file and the graph to show the description of that channel as well as the name of the physical channel.
How can I make a graph that shows me the description of each channel on the legend (instead of or in addition to the name of the physical channel)?
Sorry but I can't do it being a newbie on Labview.
08-03-2021 07:13 AM
08-03-2021 07:30 AM - edited 08-03-2021 07:45 AM
Can I ask you How?
The goal is to uniquely provide a description (or similar) to each waveform. This description must then be parametrically recalled on the graph.
08-03-2021 08:30 AM
It says in the link i provided.
Wire a Description string to Plot.Name with the ActPlot set to what you need (presumably for loop counter since you use it to name a scale)
08-03-2021 09:24 AM
The VI is big and cointains many other types of AI. I can't come up with the robust solution. 😞 😞 😭
08-04-2021 02:04 AM
This work could possibly also be done at the AIVoltage level, but I can't connect a multi array. Can you help me?
08-04-2021 02:39 AM
You can use DAQmx Flatten Channel String when setting up multiple channels.
08-04-2021 02:48 AM
Very good!!! thank you so much guys.
