Associate a description to the physical channels to be displayed on the graph and output file
I would like to associate a descriptive name to each channel. I would like the save file and the graph to show the description of that channel as well as the name of the physical channel.
How can I make a graph that shows me the description of each channel on the legend (instead of or in addition to the name of the physical channel)?
Sorry but I can't do it being a newbie on Labview.
Message 1 of 8
(1,650 Views)
How do i programmatically change plot legend names
Just wire your channel descriptor to Plot.Name
Message 2 of 8
(1,632 Views)
Can I ask you How?
The goal is to uniquely provide a description (or similar) to each waveform. This description must then be parametrically recalled on the graph.
Message 3 of 8
(1,628 Views)
It says in the link i provided.
Wire a Description string to Plot.Name with the ActPlot set to what you need (presumably for loop counter since you use it to name a scale)
Message 4 of 8
(1,612 Views)
The VI is big and cointains many other types of AI. I can't come up with the robust solution. 😞 😞 😭
Message 5 of 8
(1,602 Views)
This work could possibly also be done at the AIVoltage level, but I can't connect a multi array. Can you help me?
Message 6 of 8
(1,546 Views)
Accepted by RobotC08
You can use DAQmx Flatten Channel String when setting up multiple channels.
Message 7 of 8
(1,541 Views)
Very good!!! thank you so much guys.
Message 8 of 8
(1,537 Views)
