Array of waveform out a loop
As a new Labview Member, I wanted to optimise my code. For that, I needed to loop the code bellow. I though that the code would give me 3 arrays, each for a loop, but for now, it only updates the same array. So, do I have a problem with my code or it isn't achievable that way ?
Thank for reading.
(2,621 Views)
Hi Staken,
Yes, as there is only one array, stored in the feedback node…
What exactly do you want to achieve?
What do you want to optimize?
(2,598 Views)
I think that this would help.
https://images.youracclaim.com/size/110x110/images/7c5d31f5-2069-4618-ba59-b710c2b6bbe4/CLD.png
(2,557 Views)
Okay, so here my 'before' code.
It Initialise, read data, and store it in the feedback for each data.
I wanted to regroup the code in a loop, so it would be easier to modify and to read.
But i need it to stay that each data has her own waveform chart.
So I wanted to use the loop, and keep the feedback for each.
Sorry if im not very clear.
(2,500 Views)
I'm using LV 2016, so I can't load your VI.
And I couldn't find the function you use to convert the waveform to the string.
Can you convert it or tell me the name of it?
(2,499 Views)
Accepted by topic author Staken
Hi Staken,
That's not a string, it's a cluster.
(No idea what it's good for in this special application - the waveforms itself consist of clusters…)
See this:
(2,490 Views)
This is what i wanted, Thx you both of you.
(2,474 Views)
