Arbitration of read/write of FPGA Memory Array
I would like to access in read/write to a FPGA Memory Array from multiple location at different clock domains, with FPGA Memory backed by Lookup Table.
Is the arbitration performed per-address of for the whole array?
In the documentation https://zone.ni.com/reference/en-XX/help/371599P-01/lvfpgaconcepts/fpga_memory_items/ it mentions issues only for simultaneous access for FPGA Memory backed by Block Memory.
Emanuele
(784 Views)
No, it's not performed per address.
It's per callsite. Per access.
Timing will vary depending on whether another process is currently reading / writing or not.
(780 Views)
Then if I have 100 separate callsite, even in different VIs, writing the same Memory Item at different addresses (0..100) they will arbitrate the access to the same Memory Item resource.
(774 Views)
That's my understanding, yes.
(762 Views)
