Application resolution
How can I fit my application to the resolution of any computer.
Message 1 of 14
(769 Views)
Hi Dhruv,
Are you talking about different monitor/display resolutions?
  • Learn about using splitter bars and the pros/cons of automatic scaling in LabVIEW.
  • Learn about providing different VIs (regarding the frontpanel) to fit for different resolutions.
  • Learn about using subpanels to adapt UI to different resolutions/window sizes…
Message 2 of 14
(764 Views)
Are you asking for how to fit a VI window to the screen? Look at VI properties:
If you are asking for something else, please be more specific.
Certified LabVIEW Architect
Message 3 of 14
(751 Views)
No here I am asking to change the resolution for my application to the windows PC in which I installed it.
Message 4 of 14
(739 Views)
Can you provide any example for this. Because I used splitters but the Font size for number controls like string,numeric doesent not change.
Message 5 of 14
(737 Views)
Hi Dhruv,
Using splitter bars does not change any properties of other FP elements within the panes, they just help to design resizable frontpanels!
When you want to change properties of FP elements then you need to program that on your own…
Message 6 of 14
(732 Views)
Ok that I have tried this but is there any other way to do it.
Message 7 of 14
(715 Views)
What is "this" and what really is "it"? (we cannot tell which post you are reptying to!)
You need to describe exactly what you are trying to do, for example:
  • I  have a carefully designed front panel for e.g. a 1920x1080 screen and my friends wants to run it on a computer with a 640x480 screen. How is that supposed to look like?
In general, most front panel elements and fonts are pixel based and don't scale well, so never set them to auto-scale to the pane. Never ever!!! Single elements, such as graphs typically scale well IF (and only IF!) they are in their own pane. That's where the use of splitter bars comes in that has been mentioned.
Can you show us a picture of your front panel and explain how things should scale?
Here's one mf my examples that uses three panes, each pane scaling in a different way to keep things clean. Works great!
Message 8 of 14
(671 Views)
Hi Dhruv,
whatever computer you want to use. do as shown below.
change to 100%
Message 9 of 14
(642 Views)
Here is the screen which I want to fit to 1920X1080 resolution
Here I used decorations, buttins,string controls,enum and table. but when I try to fit this to my desired resolution. It streches like
Message 10 of 14
(633 Views)
