06-16-2014 05:21 AM
Hello..
I want to draw Antenna radiation pattern in Labview.
In Polar Plot VI, it is done, but it is a 2D plot.
How to turn it into 3D? Please Help.
Refer these images to compare..
2D Plot.. 3D Plot..
06-16-2014 06:00 AM - edited 06-16-2014 06:08 AM
By Mistake the Images were not attached..
These are the images..
2D to 3D:
06-16-2014 08:23 AM
hi Nayan,
for any 3D plot you need to have 3 axis data. Now once you have that its prety simple to plot it. Refer to 3D contour plot.vi and 3D surface plot.vi in the labview examples.
Best Regards
06-16-2014 08:35 AM
Thanks..
I have 2D data (i.e Phase Vs Magnitude).
I can plot it as a 2D polar plot.
As you said that I need a 3rd Diamension, What would it be?
I saw examples, and tried to put my data, but each time the 3D graph was Uneven.
Can you suggest something.
Here I have attached my VI and a CSV file to read.
06-16-2014 09:06 AM
can you change the vi to version 12 or below as I dont have LV13
06-16-2014 12:56 PM - edited 06-16-2014 12:57 PM
@Nayan wrote:
Thanks..
I think you really need to rotate the antenna 90 degrees and take another set of 2D data or take 3D data from the start.
I can not imagine any antenna type that is going to have a nice round radiation pattern that is equal both vertical and horizontal like you want to show, except maybe a helical.
Most antenna radiation patterns are going to be wide on one axis and flat(er) on the other. That is why as frequency increases antenna polarity begins to matter more and more.
06-16-2014 03:43 PM
Yep, no cheating. What you are doing is like taking a slice of earth at the equator and saying that the rest of the earth is exactly the same.
06-16-2014 11:51 PM
To nolsqn,
I have attached the VI in LV12.
To RTSLVU,
I dont want exactly the same Pattern that was shown in the image, It was just to show what kind of thing I want to do.
I just want a 3D pattern.
I dont know how to give data so that to have a 3D pattern.
I only have 2D data and I cannot do the rotation or any further steps to have a 3D data.
So I will need to have a fake data.
What kind of data will help me to have such kind of patterns. (means how to arrange the data in arrays, matrices etc.)
06-19-2014 08:42 AM
hey nayan,
sorry for the late reply. Actually I would use the matrix form as I find it easy to use and understand while working with 3-D stuff. So I edited some of the things in ur VI , have a look at them. Now I dont remember much details about rediation patterns but what I recal is that normally the reading of radiation patterns are in spherical cordinate and needs to be converted into cartesion cordinate before ploting 3D graph.
06-24-2014 05:28 PM
Hello, I need to do exaclty this but I have multiple Magnitude and Angle plots (Files). Has anyone done a Radiation Pattern with multiple data files? If anyone can offer some suggestions please let me know. I will try to modify the above vis to work with multiple data files.
joe
