04-06-2010 09:00 AM
04-06-2010 01:25 PM - edited 04-06-2010 01:26 PM
John,
Can you go to File > VI properties on your subVIs and check your settings under Window Appearance > Customize. See whether Show Front Panel when Loaded is checked. Just to clarify, you said the subVI front panels get opened when you load your top level VI (as opposed to when you run it), correct?
04-06-2010 02:55 PM
