Adding NI-XNET Bus Monitor Statistics on LabVIEW
Hello everyone,
I want to check my CAN state. I want to see Ext. Frames Sum, Ext. Frames / Sec, Error Frame Sum etc. on front panel. I tried to use Property Node. I didn't get any results.
I want to create an error if the number of Ext. Frames / Sec differs by +-5%. I would appreciate it if you could explain it with a vi file. If you have any other suggestions for CAN control, I'd like to hear them.
Yours sincerely! Thanks in advance.
Message 1 of 1
(416 Views)
