Add a VI to a project using scripting from a quick drop plugin
I have written a quick drop plugin which creates and saves a unit test from a template and adds it to the block diagram of the open VI and puts it in a diagram disable structure.
I want to also add this newly created VI to the project in a virtual folder called 'Tests' in the hierarchy level that the open VI is currently in.
There are a few things that I cannot work out
  • How to identify where the current VI is in the project (In terms of if it is in a library, in a virtual folder etc)
  • What target the current VI is in
  • How to add the new VI (unit test) to a particular virtual folder in a project/library
  • How to create a new virtual folder
I think this may end up being too complicated but I would be keen to know if anyone can think of a way of solving some of these points.
For reference I have attached the current quick drop plugin I have cobbled together very quickly to see if it is actually of use.
(952 Views)
Accepted by topic author Worle
Here's your first two.
(921 Views)
And your 2nd two:
(919 Views)
Here it is in LV 2017
(918 Views)
That is exactly what I was after. Thanks
(854 Views)
