Accessing ESP8266 with TCP/IP
NodeMCU.jpgTCP VI.jpgHi,
I'm doing a personal project acquiring output voltage from a solar panel. I have read from other sources regarding the esp8266 TCP/IP with labview to solve my problem but was still unsuccessful.  I need to monitor the dc motor voltage using the Esp8266 WiFi module. For the programming side, I am using LabVIEW 2013 and Arduino IDE ver 2.0.4. To test if my esp8266 works, I tested some programs download from the internet for the esp8266 (write and read text) and obtained the IP address, which is successful. Next, I verify with an input voltage from the same esp (3.3V pin) and connect to the A0 pin and monitor via the serial monitor. I received a value of 1024 which is correct for a 10-bit ADC. The problem arises when I used LabVIEW. I applied a dc voltage of 1V from a power supply (-ve terminal power supply connected to ESP Gnd) and I set the IP address with the address I obtained earlier with the server port set at 8000. I run the VI and receive an error message (error 56). The error starts from the TCP Read node. I changed the input of A0 by connecting the A0 pin to the ESP 3.3V pin. Somehow the VI shows no error and a value of 1024 was displayed on the front panel. If someone knows what is happening here please share. Tq
(2,890 Views)
Are you sure, NMCU2 is still reading and responding on TCP? You could monitor with WireShark.
(2,853 Views)
Error 56 means a timeout.  You have it set to read 4 characters.  If you get "1024" and that's 4 characters, then no timeout.  But if you have it unconnected and should get something shorter (like just 1 character for "0") then it gets one character, tries to wait for 3 more, then errors out.
Have a look at the help for TCP read, specifically the "Mode" input:
I'm guessing you might want "Immediate" instead. You could try that.
(2,838 Views)
Accepted by Ledang
Hi Kyle,
Thank you for the reply. At the TCP Read node, I select the mode to "immediate" and bytes to read = 4 and it works.
Thanks again. God bless you!
(2,818 Views)
