05-11-2022 11:50 AM
how can i make automatic static test in LabVIEW via arduino ?
there will be mesuring card as an input ...
but at firt i need to pull out probability of code word
"moj priklad.vi" how can i edit this for static testing ?
"Express Static test.vi" is for static test but i need those two voltages
and connect this together for automatized testing
05-12-2022 01:14 PM
hello,
i need to make static test for AD Converter via arduino
arduino is conected via LINX ...
how can i take two voltages from graph ?
i need those two voltager to count probability
05-12-2022 01:51 PM
Hi Samuel,
no need to start new threads for the same topic!
It also would help to attach your VIs in a downconverted version (File->Save for previous) to allow a broader audience to look at them. Not everybody is using LV2021 yet…
05-13-2022 05:39 AM
hello,
here are VIs in a downconverted version
05-13-2022 11:32 AM
Hi Samuel,
Right now you read just one channel from your Arduino. Where do you think are "two voltages" in those readings?
When you need to read two voltage signals then you should read from two channels…
(That other VI "ADC static test" is rather pointless as its subVIs are missing!)
05-13-2022 11:36 AM
here you are
05-14-2022 12:00 PM
05-14-2022 02:50 PM
i need to make conversion law from that entry signal
