07-06-2013 02:20 PM
I have built a NXT Solar Station to track the sun and focus the light onto a solar panel. In order to make it function, I have also made a NXT Program. There are two motors: Motor A rotates the base, and Motor B changes the angle of the panel. Light sensor readings stop the motors when the brightest location is found. So far, all that the program does is to rotate Motor B without utilizing the light sensor at all; if someone could help troubleshoot this program, that would be great.
Thank you!
P.S. The attached link opens a folder containing .rbt program file in question. It is named 'Solar Water' and you will need to download it.
07-08-2013 10:16 AM
Hello nxtfan,
Is there a way you might be able to post screenshots of your program as well? Many people, who could be very helpful, do not trust downloading files from the internet. Also, which component are you focusing on to get working?
07-08-2013 10:33 AM
08-05-2013 06:58 PM - edited 08-05-2013 07:00 PM
Here are the screenshots for rotation of the y-axis.
The x-axis will be similar. I will work on them when the y-axis is troubleshooted.
However, I am also encountering an error upon downloading and running the program.
The code is 1057. Do you have any idea as to how to solve this?
nxtfan
