03-18-2013 10:51 PM
I appears that Legos is not using LabView on their newer products. Is that correct?
I am hoping to teach my teenagers about LabView using Mindstorms. Mainly watching eBay auctions and doing web searches.
I presume the Legos software is stand-alone, in that you don't need to have a full version of LabView.
Some kits are rated as 2+ years old, 9+, etc. What kit would be good for teens, I am fairly technical.
Thanks!
03-19-2013 09:49 PM
Hi Jonsal,
LEGO MINDSTORMS is based on LabVIEW so it will be used in future releases. The Legoes software is stand-alone and you do not need a full version of LabVIEW to program it. However if you have LabVIEW you can use the NXT toolkit (which is available to free) to program in LabVIEW.
We at National Instruments cannot recommend what kind of kits to use but I can direct you to the customer services web page for LEGO MINDSTORMS as they can better guide you, please see link below.
http://mindstorms.lego.com/en-us/support/default.aspx
03-21-2013 11:09 AM
03-21-2013 11:11 AM
03-21-2013 08:28 PM
I don't believe NXT module will work will LabVIEW 6.1 as the link below does not have an option for this version:
https://decibel.ni.com/content/docs/DOC-15615
Also, I am not sure if the software is included as part of the kit or just the controller, so it would be best to talk with Lego customer support for pricing options.Please see link below for the customer support link.
