02-24-2017 07:13 AM
So originally I had labview 15 (32-bit) and 2015 legomindstorms ev3 on my computer which had windows 7 on it. I made the switch the windows 10 and everything seemed fine. But when im in labview and try to target ev3/nxt, labview stops responding and crashes.
02-24-2017 07:15 AM
Just to mention, Labview itself works fine its just when I decided to target to ev3/nxt is when it all goes haywire
02-24-2017 08:30 AM
Do you have the mindstorm addon for LV, or are you running the mindstorm reduced LV?
I'd guess the former is more probable to work.
/Y
02-24-2017 09:20 AM
According to prophecy it SHOULd work unless your system is missing some hardware requirements (Screen resolution sounds like a likely candidate)
02-24-2017 10:02 AM
Hi Jeff,
It seems Firefox blocks that link. Internet Explorer as well. Both say there is a problem with the site's security certificate.
02-24-2017 10:12 AM
@RavensFan wrote:
Hi Jeff,
Yeah it is a HTTPS,
I Googled "ev3/nxt" hit the third link
Selected "Support" from the top and then "Software Requirements" Looking under "Software>>Software Launch Issues" also mentions some MS Silverlight needs.
02-27-2017 09:22 AM
When you moved to Windows 10, was it through a fresh install or by upgrading through Windows 7? Some issues can come up if you're doing the latter.
