05-05-2019 08:50 AM
Hi Everyone,
I am new here.
I am a profession programmer. I am instruct EV3 FFL team now.
I have a problem to open ev3 project using mindstorm LABView education version 1.4.2 (20180509.1)
it always crash, and throw this kind of exception:
Unhandled exception occurred at 2019-05-05_12-30-57-AM
System.Runtime.InteropServices.SEHException (0x80004005): External component has thrown an exception.
but after my about 10 time try.( 30 minutes later ), it finally opened successfully.
I made some change , save it and close it .
the same thing happened when I re-open the file next time.
the below is my exception log.
I will attach my ev3 program and crash report.
Can anybody help me out ?
Thanks a lot
Johnny Wang
ev3-crash-wpf-2019-05-05_09-00-33-AM.log
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run(Window window)
at NationalInstruments.X3.Launcher.SingleInstanceManager.OnStartup(StartupEventArgs eventArgs)
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
at NationalInstruments.X3.Launcher.SingleInstanceManager.Main(String[] args)
Stack trace with ILOffsets:
at WindowsBase.dll.UnsafeNativeMethods.DispatchMessage (IL offset: 0xffffffff)
at WindowsBase.dll.Dispatcher.PushFrameImpl (IL offset: 0x40)
at WindowsBase.dll.Dispatcher.PushFrame (IL offset: 0x5e)
at PresentationFramework.dll.Application.RunDispatcher (IL offset: 0x1f)
at PresentationFramework.dll.Application.RunInternal (IL offset: 0xdf)
at PresentationFramework.dll.Application.Run (IL offset: 0x1d)
at MindstormsEV3.exe.SingleInstanceManager.OnStartup (IL offset: 0x92)
at Microsoft.VisualBasic.dll.WindowsFormsApplicationBase.DoApplicationModel (IL offset: 0x52)
at Microsoft.VisualBasic.dll.WindowsFormsApplicationBase.Run (IL offset: 0x178)
at MindstormsEV3.exe.SingleInstanceManager.Main (IL offset: 0x5)
05-05-2019 09:29 AM
it is student edition, that happened same in home edition too
05-06-2019 10:07 AM
Did you try to make a Force Reinstall?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8U0SAK&l=en-US
Have you tried to contact Lego Support or National Instruments support?
https://www.lego.com/en-us/service/?ignorereferer=true
http://sine.ni.com/psp/app/doc/p/id/psp-357
05-06-2019 04:51 PM
Thanks a lot.
I will give it a try.
05-09-2019 08:16 PM - edited 05-09-2019 08:25 PM
I report a defect of labview ,
can any developer have a look ?
The bad thing is the application just crash without provide any useful information for me to troubleshooting.
05-10-2019 01:06 AM
05-12-2019 03:59 PM
Thanks a lot for above replies.
I tried all solution you guys suggested. run ev3 program on different machine and clean reinstall the software.
I also sent email to Lego support team.
They told me the software EV3 software student edition is different from LABView software.
occasionally I opened the program , after I made some changes,
it suddenly crashed again.
Based on my observation, I feel the link on block especially on switch/loop block overlapped. that will cause EV3 software cannot recognize the work flow of the program.
anyway, I think EV3 software is not robust enough to handle all the situation in block programming.
05-12-2019 08:47 PM
Hi All,
Finally I think I found the root cause why the EV3 software keep crashing.
It just cannot handle a little big program.
I was inspired by one post online said EV3 software is not good for many tabs opened in software.
I watched the software , the size of my code is 197KB , it turns on occupied 850MB memory when it try to compile the program. that cause Ev3 software crashed . even my computer has 16GB memory, and memory usage is only 30%.
It finally can be opened correctly when I reduce the inactive code and reduce my file size to 180KB. it occupied about 750MB.
the program can be opened consistantly.
I hope this can help other guys.
05-13-2019 09:17 AM
Hi Jonhy,
Great to know, and thank you for an answer on how to solve
Have a nice day
01-03-2020 09:07 AM - edited 01-03-2020 09:11 AM
check that link:
https://education.lego.com/en-us/support/mindstorms-ev3/software-launch-issues
not quite sure what i have written here:
ev3-crash-sl-2019-08-18_09-31-10-PM.log
Unhandled exception occurred at 2018-08-18_05-27-25-PM
System.NullReferenceException: [Arg_NullReferenceException]
Arguments:
Debugging resource strings are unavailable. Often the key and arguments provide sufficient information to diagnose the problem. See http://go.microsoft.com/fwlink/?linkid=106663&Version=5.1.41212.00&File=mscorlib.dll&Key=Arg_NullRef...
at NationalInstruments.WireRouting.HighTowerRouting.HightowerRouter.ValidateDiagram(Point& offsetDiagram, Diagram& diagram, Terminal terminal, Point& point)
at NationalInstruments.WireRouting.HighTowerRouting.HightowerRouter.InitializeRouter(Wire wire, WireSegment endingWireSegment, Point startPoint, Terminal startTerminal, Diagram startDiagram, WireRouteDirections startDirection, Point endPoint, Terminal endTerminal, Diagram endDiagram, WireRouteDirections endDirection, IWiringBehavior wiringBehaviour, Boolean forceRoute, WireRoutingPurpose purpose, WireRouteDirections userDirection, Boolean isBranchingOperation)
at NationalInstruments.X3.Model.Wiring.X3HighTowerRouter.InitializeRouter(Wire wire, WireSegment endingWireSegment, Point startPoint, Terminal startTerminal, Diagram startDiagram, WireRouteDirections startDirection, Point endPoint, Terminal endTerminal, Diagram endDiagram, WireRouteDirections endDirection, IWiringBehavior wiringBehaviour, Boolean forceRoute, WireRoutingPurpose purpose, WireRouteDirections userDirection, Boolean isBranchingOperation)
at NationalInstruments.SourceModel.Modeling.ManhattanWiringBehavior.PreviewRouteWireSmart(Wire wire, Terminal startTerminal, Point startPoint, Diagram startDiagram, WireRouteDirections startDirections, Terminal endTerminal, Point endPoint, Diagram endDiagram, WireRouteDirections endDirections, WireSegment endingWireSegment, Boolean forceLayout, WireRoutingPurpose purpose, WireRouteDirections userDirections, Boolean isBranchingOperation)
at NationalInstruments.SourceModel.Modeling.ManhattanWiringBehavior.PreviewRouteWireToCore(WireJoint joint, WireRouteDirections userDirections, DiagramPoint endPoint, WireRouteDirections endDirections, WireSegment endingWireSegment, Terminal endTerminal, Boolean isBranchingOperation, Boolean retainPreviousRoute)
at NationalInstruments.SourceModel.Modeling.ManhattanWiringBehavior.PreviewRouteWireToPoint(WireJoint joint, WireRouteHint userHint, DiagramPoint point, Boolean isBranchingOperation, Boolean retainPreviousRoute)
at NationalInstruments.SourceModel.Modeling.WiringContext.TackCurrentWire(WireRouteHint userHint, DiagramPoint p, WiringTackBehavior behavior)
at NationalInstruments.SourceModel.Modeling.WiringContext.EndOnDiagram(WireRouteHint userHint, DiagramPoint p)
at NationalInstruments.SourceModel.Modeling.Diagram.EndWiring(WiringContext context, WireRouteHint userHint, DiagramPoint p)
at NationalInstruments.SourceModel.Designer.WiringTool.EndWiring(FrameworkElement child, IWiringEnd end, DiagramPoint p)
at NationalInstruments.SourceModel.Designer.WiringTool.EndWiringForMouse(UIPosition pos)
at NationalInstruments.SourceModel.Designer.WiringTool.HandlePreviewLeftButtonUp(Object sender, MouseButtonEventArgs e)
at NationalInstruments.SourceModel.Designer.DesigntimeCanvas.SendMouseEvent(IEnumerable`1 hitTestResult, Object sender, MouseEventArgs e, DependencyProperty tunnelProperty, DependencyProperty bubbleProperty)
at NationalInstruments.SourceModel.Designer.DesigntimeCanvas.ProcessMouseEvent(Object sender, MouseEventArgs e, DependencyProperty tunnelProperty, DependencyProperty bubbleProperty)
at NationalInstruments.SourceModel.Designer.DesigntimeCanvas.DesigntimeCanvas_MouseLeftButtonUp(Object sender, MouseButtonEventArgs e)
at MS.Internal.CoreInvokeHandler.InvokeEventHandler(UInt32 typeIndex, Delegate handlerDelegate, Object sender, Object args)
at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName, UInt32 flags)
at <Unknown>.HightowerRouter.ValidateDiagram (IL offset: 0xffffffff)
at <Unknown>.HightowerRouter.InitializeRouter (IL offset: 0xffffffff)
at <Unknown>.X3HighTowerRouter.InitializeRouter (IL offset: 0xffffffff)
at <Unknown>.ManhattanWiringBehavior.PreviewRouteWireSmart (IL offset: 0xffffffff)
at <Unknown>.ManhattanWiringBehavior.PreviewRouteWireToCore (IL offset: 0xffffffff)
at <Unknown>.ManhattanWiringBehavior.PreviewRouteWireToPoint (IL offset: 0xffffffff)
at <Unknown>.WiringContext.TackCurrentWire (IL offset: 0xffffffff)
at <Unknown>.WiringContext.EndOnDiagram (IL offset: 0xffffffff)
at <Unknown>.Diagram.EndWiring (IL offset: 0xffffffff)
at <Unknown>.WiringTool.EndWiring (IL offset: 0xffffffff)
at <Unknown>.WiringTool.EndWiringForMouse (IL offset: 0xffffffff)
at <Unknown>.WiringTool.HandlePreviewLeftButtonUp (IL offset: 0xffffffff)
at <Unknown>.DesigntimeCanvas.SendMouseEvent (IL offset: 0xffffffff)
at <Unknown>.DesigntimeCanvas.ProcessMouseEvent (IL offset: 0xffffffff)
at <Unknown>.DesigntimeCanvas.DesigntimeCanvas_MouseLeftButtonUp (IL offset: 0xffffffff)
at System.Windows.dll.CoreInvokeHandler.InvokeEventHandler (IL offset: 0xffffffff)
at System.Windows.dll.JoltHelper.FireEvent (IL offset: 0xffffffff)
ev3-log-sl-2018-08-18_05-31-10-PM.log
+000.002 >> MINDSTORMS EV3 launched at 2018-08-18_05-25-09-PM
+000.002 >> OS Type: Windows
+000.002 >> OS Version: Microsoft Windows NT 6.1.7601 Service Pack 1
+000.002 >> Silverlight version: 5.1.41212.0
+000.003 >> MINDSTORMS EV3 assembly file version: 1.0.50509.1
+000.003 >> MINDSTORMS EV3 build drop: R1-X3-Dev[GC]_20180509.1
+000.033 >> In Application_Startup
+000.034 >> Starting plugin loading
+000.269 >> Starting InitializeNewRespectingForRootCatalog
+001.586 >> Starting GetExportedValue<RootCompositionHostWrapper>()
+001.597 >> Starting GetExportedValue<IClient, ConfigTokens, PreferencesManager, MultiProjectSupport>()
+001.981 >> Generated XmlSerializer for requests/responses/server messages in (seconds): 0.3570204
+001.997 >> Message queue successfully claimed.
+002.025 >> Starting GetExportedValue<VersionProvider>()
+002.026 >> MINDSTORMS EV3 version: 1.4.2
+002.026 >> MINDSTORMS EV3 running as: Education
+002.026 >> Starting setup phase 1
+002.042 >> MINDSTORMS EV3 language: en-GB
+002.042 >> Starting setup phase 2
+002.049 >> _implicitFallbackString set to ""
+002.049 >> Starting setup phase 3
+002.197 >> FallbackString is ""
+002.198 >> Starting setup phase 4
+002.376 >> Generated XmlSerializer for requests/responses/server messages in (seconds): 0.1690097
+002.668 >> Starting setup phase 5
+002.671 >> Starting setup phase 6
+002.673 >> Starting setup phase 7
+002.752 >> Starting setup phase 8
+002.752 >> Starting setup phase 9
+002.757 >> Startup done
+003.460 >> Time for CreateAndRelinquishX3ProjectInstanceAtLaunch (seconds): 0.5360307
+003.819 >> Time to load lobby (seconds): 0.3580204
+003.819 >> Editor load completed
+022.439 >> Loading project from "C:\Users\Administrator\Desktop\Projects\Robocup\Dir.ev3"
+024.661 >> Generating XmlSerializer for BlockHelpSupport took (seconds): 0.0080004
+025.595 >> Successfully loaded config file https://config.api.education.lego.com/v1/ev3_desktop_edu/win/1.4.2/en-gb
+039.925 >> Time to create XmlSerializer for MEFAndSerializationHelper (seconds): 0.0540031
+047.287 >> Time to load project (seconds): 24.8474212
+114.247 >> Failed to log block removal from canvas - [Arg_NullReferenceException]
Arguments:
+136.845 >> Unhandled exception occurred at 2018-08-18_05-27-25-PM
Arguments:
+136.845 >> App exiting (crash)
ev3-log-wpf-2018-08-18_05-31-10-PM.log
+000.006 >> MINDSTORMS EV3 launched at 2018-08-18_05-25-07-PM
+000.007 >> OS Type: Windows
+000.007 >> OS Version: Microsoft Windows NT 6.1.7601 Service Pack 1
+000.007 >> OS Bitness: 64-bit
+000.007 >> MINDSTORMS EV3 assembly file version: 1.0.50509.1
+000.007 >> MINDSTORMS EV3 build drop: R1-X3-Dev[GC]_20180509.1
+000.369 >> Bluetooth supported: True
+000.373 >> Bluetooth Primary Radio Information:
+000.373 >> Manufacturer: RalinkTechnology
+000.373 >> Software Manufacturer: Microsoft
+000.373 >> Stack Factory: InTheHand.Net.Bluetooth.BluetoothPublicFactory
+000.374 >> Hardware Status: Running
+000.375 >> Mode: Discoverable
+000.376 >> Class: 2010C
+000.377 >> Local Address: 54353060A8BA
+000.380 >> Enabling passive scan for TCP;USB
+000.407 >> Generated XmlSerializer for server messages in (seconds): 0.0210012
+000.628 >> Generated XmlSerializers for requests/responses messages in (seconds): 0.2140122
+003.311 >> Message queue successfully claimed.
+005.138 >> AppFullyLoadedEvent received
+138.190 >> App trying to exit (crash)
+138.193 >> WorkingSet64: 496,553,984
+138.193 >> PagedSystemMemorySize64: 973,544
+138.193 >> PagedMemorySize64: 455,147,520
+138.193 >> NonpagedSystemMemorySize64: 167,680
+138.193 >> PrivateMemorySize64: 455,147,520
+138.193 >> VirtualMemorySize64: 992,550,912
+140.586 >> App exiting (crash)
